- Central
- WI
- 2011 Fiesta SE Manual Hatchback
Hey all,
So I have two questions about Caster adjustment rear lower control arm bushings such as these Powerflex ones. Or any of the ones available on the market.
Powerflex Front Control Arm Rear Bushing, Caster Adjustable
Image source whoosh-motorsports.myshopify•com
I do, yes understand how changing the rear mount point of the lower control arm forward within the space of the bushing can add positive caster (which I want more positive caster).
Image source autotrends•org
My First Question is; Are these bushings a press in and then no adjustment. Or can they be adjusted after installation? I'm inclined to believe that once they are installed there is no adjustment, so you better take care and get it perfect.
My Second Question is; Has anyone already installed these or other brands, if so does it provide a noticeable improvement to handling?
Thank you in advance.
