Power window and lock issue
Rogersville
MO
2007 ford focus
I have a 2007 Focus. I bought it and subsequently found that neither the power window motor nor the power lock actuator worked on the right rear door. I've checked both with 12v direct power and they both work fine. Is there a common fuse or feed wire for them? Which fuse? It also has been a salvage vehicle due to collision. I don't know the details of the restoration. Could it be a common ground problem?
Help!! I can use a mulitmeter, just don't know where to check.
YUMA
AZ
2004 Ford Focus 2.3L Base Model
So, have you traced the wiring harness. I've seen lots of restoration videos and where the damage originates the wiring harnesses are mangled. Also, if it was possibly a flood salvage then there could be corrosion in the harness near that door. Things to consider. If you can find both ends of the harness to that specific door, I would check for continuity of all the wires in that door to ensure no harness breaks exist.
