Ford Focus 1.8 Zetec (2000)
I'm having an issue with the cooling fan control.
The PCM does not activate either the low-speed or high-speed cooling fan, even when the engine coolant temperature reaches 108°C.
Here are the details:
Does anyone have any suggestions on what could be causing this issue?
Thanks
- There are no DTCs related to the cooling fan or its electrical circuits.
- The cooling fan operates normally in both low and high speeds during an active test.
- When the engine coolant temperature (ECT) sensor is disconnected, the fan runs at high speed, which indicates the fan circuit and PCM output are functioning.
Thanks
