2002 Ford Focus SE Wagon Parking Lights will not shut off SOLVED
jharasmoff
Port Mellon
2002 ford focus se
Hello,
Long story short I was installing an aftermarket stereo and after I reconnected the battery and had everything working I noticed the parking lights absolutely will not turn off unless the battery is disconnected. The warning chime for lights left on is going but no matter what i do with the headlight switch they stay on. I pulled the fuses for both sides and the lights went off but the chime continued. I am having difficulty figuring out what relay to check as nothing on the chart specifically mentions the parking lights.
If anybody could walk me through some things to try with troubleshooting this it would be much appreciated!
Thanks,
Joseph
Edit: Found the issue used a redundant wire behind the stereo I did not think the stereo wires could give power to the parking lamps.
