Training the TPMS on your Ford Focus
MKIIIRS
  1. With the ignition OFF, press and release the brake pedal.
  2. Using the start/stop switch, position the ignition from OFF to RUN 3 times, ending in the RUN position.
  3. Press and release the brake pedal.
  4. Position the ignition to OFF position.
  5. Using the start/stop switch, position the ignition from OFF to RUN 3 times, ending in the RUN position.
  6. The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN Left Front (LF) TIRE.
  7. NOTE: It may take up to 6 seconds to activate a tire pressure sensor. During this time, the special tool must remain in place at the valve stem.
Place the special tool on the Left Front (LF) tire sidewall at the valve stem. Press and release the test button on the special tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the BCM.
Special Tool(s): 204-363 Tool, Tire Pressure Activation
8.Within 2 minutes of the horn sounding, place the special tool on the Right Front (RF) tire sidewall at the valve stem and press and release the test button to train the Right Front (RF) tire pressure sensor.
9.NOTE: Do not wait more than 2 minutes between training each sensor or the BCM will time out and the entire procedure must be repeated.
Repeat Step 7 for the Right Rear (RR) and Left Rear (LR) tires. The procedure is completed after the last tire has been trained. When the training procedure is complete, the message center (if equipped) will display TIRE TRAINING COMPLETE. For vehicles not equipped with a message center, successful completion of the training procedure will be verified by positioning the ignition to OFF without the horn sounding. If the horn sounds twice when the ignition is positioned to OFF, the training procedure was not successful.
