Just another Fox Body Project
D
Thread Starter #21
Well, its ready to go to the chassis shop. Depending on how the car sits with the rear control arms that are being made for it, I may go back to the old springs to lower it.
BCN_7639 by Detroit Style, on Flickr
So, this one time I tried to put a 100lb 5ft long hood on a car by myself...
BCN_7652 by Detroit Style, on Flickr
BCN_7651 by Detroit Style, on Flickr
BCN_7642 by Detroit Style, on Flickr
BCN_7649 by Detroit Style, on Flickr
BCN_7655 by Detroit Style, on Flickr
BCN_7658 by Detroit Style, on Flickr
It's last night home for a while.
BCN_7664 by Detroit Style, on Flickr
On its way to Detroit for some chassis work.
BCN_7666 by Detroit Style, on Flickr
BCN_7667 by Detroit Style, on Flickr
D
Thread Starter #23
200,000 miles took its toll on the front control arm bolts (all of the suspension bolts really).
PSA: Do not stick your camera this close to a lit torch and oil/grease covered parts.
BCN_7933 by Detroit Style, on Flickr
BCN_7930 by Detroit Style, on Flickr
BCN_7926 by Detroit Style, on Flickr
BCN_7924 by Detroit Style, on Flickr
Someone out there must want a 5 lug conversion for the front of their Mustang... BUY THIS!!
BCN_7938 by Detroit Style, on Flickr
*No cameras or camera equipment was injured during the making for these pictures.
D
Thread Starter #25
D
Thread Starter #27
Recently, I had a snow tire let go on the beater and having killed two factory 18s, I decided to order to wheels for it. Downfall, no one had them in stock due to the bolt pattern. Well, the new wheels came in today so, I swapped the tires from the factory 18s over and put them on the car.
BCN_8271 by Detroit Style, on Flickr
BCN_8270 by Detroit Style, on Flickr
BCN_8268 by Detroit Style, on Flickr
BCN_8265 by Detroit Style, on Flickr
D
Thread Starter #28
The rear coil overs came in yesterday and I put them on today. It is safe to say that with no weight in the car, I'll have to raise it up about an inch and do some fender work.
BCN_8353 by Detroit Style, on Flickr
BCN_8370 by Detroit Style, on Flickr
BCN_8374 by Detroit Style, on Flickr
BCN_8380 by Detroit Style, on Flickr
BCN_8376 by Detroit Style, on Flickr
BCN_8390 by Detroit Style, on Flickr
Yeah, I think I need to pull the fenders out a bit.
BCN_8395 by Detroit Style, on Flickr
BCN_8393 by Detroit Style, on Flickr
D
Thread Starter #29
Playing around with potential turbo placement and debating going to a tube front to make more room.
BCN_8629 by Detroit Style, on Flickr
Ready to pull all the wiring out of the car, a Mustang dash and a new column as well as finish pulling out the sound deadening.
BCN_8640 by Detroit Style, on Flickr
Figured that I'd knock out some work today so, here are the mid evening update. The column support is out, the main harness is about ready to be fully pulled out of the car and, the parking brake assembly is gone for good.
Parking brake cable is dying to get out of there.
BCN_8654 by Detroit Style, on Flickr
BCN_8663 by Detroit Style, on Flickr
The quicker, more pleasant way of taking the wiring out of a car.
BCN_8673 by Detroit Style, on Flickr
BCN_8676 by Detroit Style, on Flickr
It's starting to look like a welcoming home to a Mustang dash.
BCN_8677 by Detroit Style, on Flickr
D
Thread Starter #30
Started to make a mold fo the deck lid in order to make a lighter than steel version.
BCN_8699 by Detroit Style, on Flickr
The car was a really nice color before the last owner made it flat black.
BCN_8703 by Detroit Style, on Flickr
Lots of waxy goodness ( I knew I kept this garbage wax for a reason).
BCN_8705 by Detroit Style, on Flickr
Made sure to keep the hump for all the Lincoln looks as possible.
BCN_8717 by Detroit Style, on Flickr
Left off with this for the night, tomorrow I'll attack the top side.
BCN_8720 by Detroit Style, on Flickr
Well, for a first attempt at a large panel mold, i don't think its too terrible. There is a lot of room for improvement but, not horribly terrible.
BCN_8721 by Detroit Style, on Flickr
BCN_8722 by Detroit Style, on Flickr
BCN_8723 by Detroit Style, on Flickr
BCN_8728 by Detroit Style, on Flickr
BCN_8729 by Detroit Style, on Flickr
BCN_8730 by Detroit Style, on Flickr
BCN_8731 by Detroit Style, on Flickr
D
Thread Starter #31
Started cleaning up the engine bay, there will be filler panels made for the firewall and then everything will be blasted, sealed and painted.
BCN_3282 by Jason Bacon, on Flickr
BCN_3280 by Jason Bacon, on Flickr
I haven't touched this car in a while, mostly due to have 0 money after bills have been paid but, that being said, I did just get back from the store, I am going to attempt to de-power the rack and get it setup to work with the SN95 spindles. The debate is, do I make a video of it or just a few pictures.
BCN_5541 by Jason Bacon, on Flickr
BCN_5542 by Jason Bacon, on Flickr
BCN_5543 by Jason Bacon, on Flickr
BCN_5545 by Jason Bacon, on Flickr
BCN_5546 by Jason Bacon, on Flickr
Well, the de-powering failed. The seal at the top of the steering shaft isn't removable. The good news is, the rack must be so far gone that, its actually real easy to move by hand so, I put it back together and put the SN95 bits on it. Tomorrow I need to get some sealant to seal up the ports for the fluid and install the rack again. It will be nice to not have floppy pickle wheels to make moving the car easier.
I should also say, I have been dicking around with the engine bay, slowly getting it stripped and ready for paint and fab work.
14902856_1730454500612259_6946149336847125794_o by Jason Bacon, on Flickr
Musical motivation provided by:
[video=youtube;gnslHZB_ukc]https://www.youtube.com/watch?v=gnslHZB_ukc[/video]
D
Thread Starter #32
Decided to gut the dash since it weighs 100lbs, even with just the steel structure left, its still a tanks worth of weight. I think it needs to be made out of a composite of some sort.
DashGutting-5551 by Jason Bacon, on Flickr
DashGutting-5552 by Jason Bacon, on Flickr
DashGutting-5556 by Jason Bacon, on Flickr
DashGutting-5580 by Jason Bacon, on Flickr
DashGutting-5581 by Jason Bacon, on Flickr
DashGutting-5583 by Jason Bacon, on Flickr
DashGutting-5584 by Jason Bacon, on Flickr
Tonight's musical motivation:
[video=youtube;x-YdouotPTg]https://www.youtube.com/watch?v=x-YdouotPTg[/video]
D
Thread Starter #33
I decided to fill in all the holes that are found in the engine bay of this platform and with that, I realized I need to fire up the weld I got for Christmas years and years ago that I never touched. It's your average Harbor Frieght Fluxcore box but, that should be more than enough for this project. I had some spare metal laying around from other projects so I decided to make a few test passes to see what I can do and how bad I am.
I have no real idea what Im looking at here. I know the splatter is just a by product of Fluxcore stuff and, i know I was starting to get decent beads to lay down but, past that. It looks like Greekaphilgy.
First attempt:
Attempt 1 was to weld the bent steel the the steel plate. The top weld was my most recent on that attempt and, where I turned up the speed the wire. Clearly, the top weld was the best one there. The weld to the right was a test past to see how the wire speed increase actually worked when applied to metal.
DashGutting-5606 by Jason Bacon, on Flickr
DashGutting-5608 by Jason Bacon, on Flickr
Second attempt:
Cut out a small piece and weld it to create a little wall. That didnt turn out well, trying to weld that little piece with no means of holding it up resulted in burning through (lower left corner) and just really sloppy looking welds. Not being happy, I took a 5lb mini sledge and bent it over and as you can see, it held. Then I tried to weld it down while filling the gap that is obviously left with that type of bend. After that, I just decided to make a few lines that resemble letters or snakes.
DashGutting-5616 by Jason Bacon, on Flickr
DashGutting-5620 by Jason Bacon, on Flickr
Musical inspiration provided by:
[video=youtube;YA6SRE2JQBk]https://www.youtube.com/watch?v=YA6SRE2JQBk&list=PLBSGkiRA2q6d0CV6ilK_pkSxyq_lmliMw[/video]
This may hurt some but, all of the connectors are cut off and all of the wiring from the car is ready to go to the metal recycler.
15974975_1774253349565707_8828428609154979457_o by Jason Bacon, on Flickr
D
Thread Starter #34
Another piece to the puzzle, thanks to Bastard SVT, a free Team Z radiator support.
16797619_1800002993657409_826622344870984824_o by Jason Bacon, on Flickr
Let's see if I end up having to do a tube front after welding this thing in and turning things into liquid.
17622603_1824121184578923_1694905473_o by Jason Bacon, on Flickr
Well, I am officially not a welder but at least I didn't burn the place down and the welds hold the weight of me. Just need to do some trimming so the turbo fits into the core support and can be bolted to the turbo holder pedestal thinger. Soon, I'll have no choice but to finish cleaning up the engine bay.
BCN_5701 by Jason Bacon, on Flickr
BCN_5704 by Jason Bacon, on Flickr
BCN_5705 by Jason Bacon, on Flickr
BCN_5707 by Jason Bacon, on Flickr
BCN_5712 by Jason Bacon, on Flickr
BCN_5713 by Jason Bacon, on Flickr
