Ford Focus Forum
Follow us on Twitter Follow us on Facebook Follow us on Google+
Register
Go Back   Ford Focus Forum > >
MK1 Focus - Forum to discuss about general questions, window tinting, exterior body, interior and lighting upgrades for the first generation 2000-2007 Focus.
User Tag List
+ Reply To Thread
Thread: P0171 DTC, please Help!!!!
Thread Tools Display Modes
Unread 07-10-2017, 11:26 AM   #1
odlarhg
Focus Rookie
Member#: 69
What I Drive: 2004 blue Ford Focus Duratec 2.3 PZ
Forum Reputation: 1 odlarhg Good Standing Member
Buy-Sell-Trade Rating: (0)
Hi
First of all, I apologize to you for my limited English. I speak very little English.
I am from Guatemala and I have a 2004 Ford Focus Duratec 2.3 PZEV. Everything was working well, but several weeks ago the engine began to hesitate. Then it began to lose power to the point of shutting down the engine (Especially when uphill). I have an Innova 3030 scanner and when I connected it it showed me a P0171 error.
The report that shows me the software of the scanner is the one below this message. Can you help me interpret this report? Could you give me some clues as to why this code is being generated and if the values in the report are normal or are there any that are wrong?.
Here in Guatemala it is not so easy to find a service center that will fix these vehicles well since it is not a vehicle that would have been imported by the distributor. Please help me, I need to repair my car.
Thank you.
Parameter Description
Results
DTC for which Freeze Frame was Stored
P0171
Fuel System 1 Status
Closed Loop
Fuel System 2 Status
Not Supported
Calculated LOAD Value
30.20 %
Engine Coolant Temp
190.40 °F
Short Term Fuel Trim - Bank 1
42.19 %
Long Term Fuel Trim - Bank 1
25.78 %
Intake Manifold Absolute Pressure
8.59 inHg
Engine RPM
1,274.50 rpm
Vehicle Speed Sensor
14.29 mph
Ignition Timing Advance #1 Cylinder
12.00 °
Intake Air Temperature
102.20 °F
Air Flow Rate Mass Air Flow Sensor
0.65 lb/min
Absolute Throttle Position
17.65 %
Commanded Secondary Air Status
Atmosphere / Off
Oxygen Sensor Output Voltage (B1-S1)
0.52 V
Short Term Fuel Trim (B1-S1)
42.19 %
Oxygen Sensor Output Voltage (B1-S2)
0.05 V
Short Term Fuel Trim (B1-S2)
99.22 %
Oxygen Sensor Output Voltage (B1-S3)
0.05 V
Short Term Fuel Trim (B1-S3)
99.22 %
odlarhg is offline
       Log In To Reply
Old Advertisement  Remove Advertisements
Ford Focus Forum
Member#: 1
Unread 07-10-2017, 10:21 PM   #2
rooSTer
Focus Rookie
Member#: 39
Forum Reputation: 1 rooSTer Good Standing Member
P0171 sounds like you have a vacuum leak. First check all your hoses, then check your PCV valve to see if it needs to be replaced.
rooSTer is offline
       Log In To Reply
+ Reply To Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ford Focus Forum is the premiere Ford Focus community. We offer one of the largest collection of Ford Focus related news, photo gallery and technical articles. Share your favorite Ford Focus, Focus ST and Focus RS photos as well as engage in discussions with fellow Ford Focus owners on our message board.
Focus RS Forum - Focus ST Forum - Focus SVT Forum - MK1 Focus Forum - MK2 Focus Forum - MK3 Focus Forum
